BinaryExpert
I have a 2019 Max and hear subtle metallic noise and vibration randomly from near my front wheel (They are usually pronounced within first 5 minutes of driving in the morning). From my service visit, I have learned new information to share with you.
SSM 48088 - 2019 F-150/Expedition/Navigator - 4WD - Revised IWE Operation Strategy After Initial Start Up
2019 F-150/Expedition/Navigator vehicles equipped with four-wheel drive (4WD) have a revised transfer case control module (TCCM) strategy that will affect IWE operation after initial start up. The TCCM will not energize the solenoid to supply vacuum to the IWEs after the initial key cycle and a driven gear is selected. The IWEs will remain engaged for 0.8 km (0.5 mi) when the temperature is above 0 C (32 F) and 3 km (2 mi) when below 0 C (32 F). The strategy changes were implemented to improve vacuum supply management and axle warm up in cold temperatures. The engine must run for a minimum of 5 minutes to build sufficient vacuum before performing any vacuum related testing. Refer to the workshop manual section 307-08A.
