4x4 front differential part question?
Wal92tt
Riverview, Fl
Regarding part #1 in this diagram, what is the part # and name? I believe this part snapped on our 99 EB 5.4 4x4? I'm able to pull it out a few inches and the differential makes a loud noise as this part and whatever is connects to inside are clanging together. I've pulled the 4x4 fuse and no noise, but I'd like to repair it and have access to 4x4.
Now as I look at this diagram, I'm not sure that part #1 snapped, maybe it simply popped out or whatever was retaining it inside? What parts hold it in? If part #1's plines are still good, maybe I can getaway with only replacing the parts holding it inside?
Please include all part #'s if possible when responding, and thank for your help!
98eb5.4
s. ontario
my 99 manual shows
Item Part Number Description
1 ----3A381 Axle --shaft (LH)
the above looks the same as yours
not this tho
2 ----N808765-S --Snap ring
or on your pix could be they are #4
your diagram doesn't look like mine, or there are major diffs
Wal92tt
Wal92tt
Riverview, Fl
Thanks, I'll have to find this info at our library. Looks like all I need is the snap ring, #2, remove the diff cover to snap in place and refill with fluid. Hopefully it goes as simple as this...... I'll update once I get around to doing this, maybe next week....?
othermrsikes
