akorcovelos
Just under 3k miles ago I replaced the entire timing system, cam sensors, VVT solonoids, plugs, oil pump, water pump, and one coil on our '06 Expedetion. Changed oil with proper Motocraft oil and filter.
Tonight my Wife calls telling me its running really rough, flashing CEL, and dies at stops. She said it was cutting in/out where it would run fine for a couple minutes then start crapping out again. I'm having it towed home now...
I just happened to have left my code reader in the truck so I have her pull the codes. P0011, P0022, P0171, P0305, and P2198. Looks like a both cams are throwing codes, and an o2 sensor, and misfire on cyl 5.
Am I seriously looking at more cam phaser issues on parts that have less than 3k miles on them? The fact it's throwing both sides seems odd. Not sure what else would cause this considering I replaced every common trouble component on the engine...
She just filled up the tank, maybe bad gas? I didn't change the fuel filter, maybe thats clogged, though not sure why that would cause cam codes. Same with the fuel pump failing, why would that cause cam codes? I just don't believe both phasers crapped at the same time.
