From my experience, there is no reason for oil additives unless the engine is sludged up. As you know, sludge develops from excessively long oil change intervals, short frequent trips not allowing the engine to fully warm up and burn off condensation and / or running the engine low on oil for a extended time. Since your primary mission is pulling a trailer, your expo is being driven in a matter that does not produce sludge. Your oil change interval is awesome so if I was a betting man I would say your engine is sludge free. When I replaced the timing components at 104,000 miles, my engine had no sludge build up at all, just some darker varnish on the drivers side cylinder head because that where the PCV valve is located. Timely PCV valve replacement is encouraged. Rest easy, you are doing the right things to extend the life of your engine. P.S. My uncle had a 2014 Expo that had 220,000 miles with all original timing components and roller followers that ran perfect until it got totaled in a car accident.
