JustWarminup
So just a all in all, it went well, still makes a small noise. Changed the oil pump. I'm guessing it's the o-Ring seal around the pickup tube. I didnt think about it needing to hold pressure, or maybe a gasket was needed behind those iron tensioners.
I replaced a manifold and decided that the other one is not worth it for all that tap and removal. and I'll wait till the motor goes bad, replace either the motor or heads up depending on what happens.
