5.4L 3v Timing job: tips, tricks and lessons learned
eddytheexpy
Phoenix, AZ
I know the timing job has been beaten to death on this forum but here's my notes on the job (my model: 2011 EL Limited 4x4) to help others out in the future. Some of this may seem like a no-brainer but this is geared towards settling an apprehensive novice's mind before starting the job and allow for planning. The most involved thing I've done before this job was a radiator replacement so I was super scared of having the engine torn apart and having an "uh-oh, what do I do now!?!?" moment. A vast majority of this list I learned on the fly since there wasn't a heads up about it and a few things on this list I picked up from this forum or elsewhere and found it incredibly helpful so figure that I'll put it here so it's all in one place. So, let's get into it!
1) Oil Pan?: just plan to pull the oil pan at the end. This will give you peace of mind knowing that the oil pan and pick-up tube is clean considering all the debris you'll be generating and it also gives you a much better angle to confirm the torque on the pick-up tube bolts if replacing the oil pump. More on this topic later.
2) Tools: here's a breakdown of tools I used that are specific to this job or isn't a common item to have around. This list shows: what I used, if FTM recommended, if I found a cheaper alternative, what that alternative was and my notes on it.
Itemdid FTM Recommend?Did I get the same item/brand?Substitute brand usedNotes
crank shaft pulley puller
yes​
no​
generic HF 3 jaw pulleron my model the harmonic balancer didn't have the screw holes and had 3 wings on the balancer (check this before you start the job)
phaser holding tool, crankshaft positioning tool
yes​
no​
MOEBULB kit (random generic brand on amazon)worked 100% perfectly
roller follower removal tool
yes​
no​
ARES 15001 (from amazon)it worked very well despite the few bad reviews. It was tough to use but that ball on top which bad reviews mentioned I think was a feature, not a bug. if everything was lined up perfectly, the screw knob would jussssst barely catch the threaded portion of the tool.
cat claw
yes​
yes​
N/A​
VERY helpful
pneumatic fan wrench kit
yes​
no​
Not needed​
doesn't apply to my model
A/C disconnect tool
yes​
no​
not needed​
could have used it but I was definitely able to work around the A/C lines and didn't want to drain the A/C system if I didnt have to
8mm flex head gear wrench
yes​
yes​
N/A​
get it, super helpful on the oil pick up tube
Small forceps
no​
N/A​
any brand will do​
very helpful to position the oil pick-up tube bolts and had a lot of varied utility where needle nose pliers would be too bulky
magnetic pick-up tool
yes but not a brand​
N/A​
Any brand will do (used one from Walmart)lots of varied utility
250 ml wash bottle
no​
N/A​
Any brand will do, I used valchoose from amazonthis was incredibly helpful to squirt oil with accuracy onto the cam towers, cams, roller followers, etc.
cheap plastic bowl
no​
N/A​
small 25 cent halloween candy bowl from Walmartused as an oil bath for the lash adjusters. My fiancé and I don't really get anything that comes in a large enough plastic bottle that I could have just cut the top off of.
32mm axle nut socket
N/A​
Duralast (autozone)worked like a charm for turning the crank manually
Paint Marker
Yes but not a brand​
N/A​
white walmart brand paint markerdid the trick
soap stone marker
no​
N/A​
I bought it at Crate & Barrel a while back for automotive use, it was like $2 so the cheapest thing in the store for sure hahahanice faint marks that just rub away. For you don't want to use an actual paint marker
3) Busted Fasteners: Buy a variety pack of fasteners (the kind with the zip tie integrated to the fastener). You will likely break every fastener you touch.
4) crankshaft pulley bolt: if buying the ford timing kit that FTM recommends (quick note on that kit: check the seals of the chain tensioners, one of mine had a huge bump in the bead of the sealant so I contacted the seller and they sent me a new one that was way closer to flush), it comes with the crankshaft bolt even though it's not on the itemized list of parts included. That bolts costs $20 by itself. if me getting it with that kit was a fluke, just order it a la carte afterwards and you'll have it by the time you need to put it in
5) Power tools: I did this entire job with zero power tools (excluding an air compressor which you WILL need to clean dust and debris off the engine). A tip for getting the crankshaft pulley bolt on/off is plan to replace the accessory belt and use the old one to pin the crankshaft in place. theres lots of videos out there on how to do this but you'll be dead in the water if you plan on re-using the accessory belt and don't have an impact driver.
6) Gasket Ambiguity: if you've never done a gasket before (like me) you'll find there's no DIRECT instructions on how to clean the mating surfaces. Everything just says "clean the mating surfaces" and they don't show you how. It seems everybody has a different opinion on this one and making a video on it will just start WWIII in the comments section. All I'll say based off my research is: avoid using scotchbrite on the surfaces of the heads/block. its not so much about being too rough on the surface material but more about the abrasive aluminum oxide debris that comes off the scotchbrite pad and then that winding up in the engine. for the covers it seems like it's totally fine for 2 reasons: 1) you can hose those down with brake cleaner and compressed air to get all that debris out, 2) the covers are cast aluminum and the grooves for the gaskets aren't finished so it already has a rough surface anyway.
7) Advanced overthinking and overplanning, but peace of mind: get a big ol piece of cardboard and draw a 2X4 grid on it. Label each square for its corresponding cylinder and pop holes in it with a pick tool to feed zip ties through. these zip ties will hold all your cam caps and cam shafts when you take them out. As soon as you pull one out, retain its orientation and place it on its corresponding zip tie and zip it down. this way there is zero confusion or thoughts in the back of your head whether you put it back exactly how it came out and there's no possibility of mixing anything up even if you trip over the board and kick it or something.
8) oil pump priming: watch the YouTube video from Melling on how to prime the oil pump if you're upgrading it. I couldn't get oil pressure at all until I stuffed a pile of oil into the outlet that feeds into the oil filter.
9) Pulling the oil pan: I couldn't find anything about taking off the oil pan and the timing cover at the same time. In the Haynes manual for oil pump replacement it says: remove oil pan, remove timing cover, replace oil pump, then the rest of installation procedure is the reverse of the removal procedure. cool, right? well there is an "important" note on the timing chain cover installation. it says to rest the bottom of the timing chain cover on the front of the oil pan and carefully line everything up as you tip it into place. this is impossible with the oil pan off. So do the oil pan at the end, just wait 24 hours for the RTV on the timing chain cover to cure.
10) pulling the oil pan continued: the process FTM shows is pretty straight forward. However on my model there's this extra finger in the support mount for the front diff that won't let it rotate far enough to let the pan out. OK well let's see what the Haynes manual says... nope, that doesn't address my model's configuration and is wayyyy off. So, I dropped the entire front axle. however, that annoying top bolt that FTM says he usually never touches, needs to come out. The issue with that is, to fully remove it, the spot where the steering shaft and steering rack meet is in the way. DO NOT remove the steering rack, it's way too much effort. just remove the steering shaft (good opportunity to replace it btw if you're interested). Once that lower knuckle clamp of the steering shaft is out of the way, that bolt has just enough clearance to sneak out.
11) crank seal: use the old crank seal to beat the new one into place
12) Better lighting: Remove the hood, it's just 4 bolts, allows for better lighting and more space to work. I used a soap stone marker to mark the position of the mounting bracket so it went back on in the same place and closes properly.
13) driver's sider (left) wire harness: I really didn't want to pull that oil pressure sensor connector because it looked like the most annoying thing in the world to do. so I didn't. Sure, at certain times you have remember to be mindful of the wire harness like when putting the steering pump back on but it really wasn't in the way.
14) Zip ties: Have a bunch of zip ties on hand. they come in handy all over the place! they are great for holding things out of the way like hoses and the power steering pump to name a few. sometimes you have to connect a few of them to make a super long zip tie but I'll tell you, those made my life so much easier!
15) spark plugs/ignition coils: So while I was ripping apart the engine I figured I'd change the spark plugs and ignition coils as well. But I changed my mind. I left those alone because I knew they were good. just stick to the timing job and do those after you confirm success. If you have any issues, the new plugs and coils create new avenues of diagnostics to run down. Sure, the plugs are RIGHT THERE and asking for it plus, you have the coils out anyway but think of the possible head ache vs 2 more hours or relatively worry-free work. Also, if you are unlucky and have the 2-piece plugs, you can go for a drive to get the engine hot.
I think this is a comprehensive account of what I learned that isn't addressed across all the content I found. I hope this helps ease the mind, save a few bucks and makes for better planning for those undertaking this rite of passage for the DIY owners of a triton engine. If you've got a some tricks up your sleeve on this job, those will make a great addition to this thread!
spav8r
Pennsylvania
I wish I had read this before I started, but here I am at the reassembly phase! Useful tip on using the old crank seal to drive the new one in, besides getting the oil pan back in that is my next hurdle. Would you mind elaborating how you went about it? As in, did you use a block of wood on top of the old seal or something? I don't have any sockets that are big enough to fit it.
eddytheexpy
eddytheexpy
Phoenix, AZ
*putting this here for continuity of the lessons learned aspect*
TLDR: If upgrading to the HV oil pump, at least inspect the oil filter housing for gasket leaks and replace it during the job if there's evidence of a leak. Personally, I would recommend just planning to replace it considering the age of these engines now and how easy it to do while you've got everything pulled apart.
Full story:
If you decide to go with the Melling 360 HV oil pump upgrade, save yourself some hassle and read this post!
~ a week after completing the timing job including oil pan removal, I did an inspection of my gaskets to make sure they were are all making a good seal. My inspection resulted in finding out that I did an adequate job on all of them (timing chain cover, both valve covers and oil pan)! BUT the oil filter looked a little too shiny and then I noticed a drip of oil collecting on the lowest edge out it. I didn't clean the side of the block very well in that neighborhood so I couldn't tell what crud was new or old. Something had certainly been leaking oil there previously but it was never enough of a leak to collect on the oil filter like it was doing now because I definitely would have caught that during oil changes.
I took a moment to think and then realized that my oil filter housing gasket must have had a very minor leak previously and now with the cranked up oil pressure, it went from very minor to just regular minor. I'm kicking myself for not thinking of that before because it would have been super easy to do while the steering pump was out of the way.
I'm mid gasket job now and was very frustrated for days for the following reasons that I'd like to help you avoid.
First, you can't grab the lower radiator hose clamp with pliers, the steering pump is in the way. I'm not taking the steering pump off to make room. Getting that back on was a dark time in my life.
Second, Ford chose to put the lower radiator hose clamp's tabs directly in line with the metal steering pump lines so you can't use the flexible hose clamp pliers that are supposed to be the tool for the job.
Third, since I was FUBAR'd and desperate, I looked around the garage for anything that might help and saw some screw style hose clamps laying around. I was willing to try anything so I bent it into shape to just fit over the 2 clamp tabs and started screwing it down. It started to work! But then tragedy struck. With tension on the screw style clamp, the screw portion began to pivot away from me. It took about 1.5 hours and 5 different tools (continually switched between them depending on the screw's rotational orientation and the screw's position since it was moving with increasing tension) to get 12 rotations out of it. Finally, the radiator hose clamp was loose enough to get the radiator hose off. At least getting it back on will be a cake walk since the clamp has that retainer clip.
So in conclusion, save yourself time, effort and frustration by just doing the damned thing during the timing job. It's only 4 relatively easily accessible bolts after the radiator hose is off and the gasket costs $20.
drscanman
West Lafayette, IN
yes​
no​
yes​
no​
yes​
no​
cat claw
yes​
yes​
N/A​
VERY helpful
yes​
no​
Not needed​
A/C disconnect tool
yes​
no​
not needed​
yes​
yes​
N/A​
Small forceps
no​
N/A​
any brand will do​
N/A​
250 ml wash bottle
no​
N/A​
cheap plastic bowl
no​
N/A​
N/A​
Paint Marker
N/A​
soap stone marker
no​
N/A​
Besides replacing the chains, how did you determine what other components needed replaced also?
eddytheexpy
eddytheexpy
Phoenix, AZ
I just gave it the full send. A couple extra hundred dollars to make sure I never have to go in there again (assuming nothing else busts) is worth it in my opinion. Also, imagine planning on just doing the timing job and finding something else wrong so now you have to pause for a week waiting for the parts to come.
You’ve already got the valve and timing chain covers off, so just do it for the peace of mind. When I got the roller followers and lash adjusters out, just a couple were a little wonky but none of them were “bad”. I probably could have put most if not all of them back in but for the cost of 2-3 tanks of gas (I have the EL so a 33.5 gallon tank) to know they’ll be good for the rest of the vehicle’s life is a good use of the money.
drscanman
West Lafayette, IN
Thank you for sharing. You post makes sense. Thank you.
Adieu
SoCal
Regarding plugs being right there: they're ALWAYS right there and always will be.
You can swap them out without removing anything whatsoever (if nothing is messed up and you don't have the plugs that can break apart and do decide to break apart on you).
Some stretching involved and shorter folk might need a footstool or something, but I've done it twice on two different 3rd gens without taking anything else apart.
dragosa
San Tan Valley
Full story:
From my understanding M340 pump is the right one for the 2011?
eddytheexpy
eddytheexpy
Phoenix, AZ
so the M340 is the "correct" one but the M360HV is the high volume one FTM recommends which is what I used for this job. He recommends it to pair better with the updated ford roller followers and to get higher pressure through the small oil passages. The inside of my engine was pretty clean with very light varnish but out of caution since I was digging around in there, I did an oil change after 1000 miles and a second oil change after another 1000 miles before going back to regular intervals. I have a big 5 gallon jug that I put used oil in to reduce the trips to auto zone for dumping it (I've got a few vehicles so it saves a lot of hassle). When I decided to dump the used oil, the jug only had those 2 rounds of oil in it and I noticed way more sediment pasted to the bottom than usual. So it seems like something loosened up the crud in there. idk how much of that was because of the high volume oil pump or some other factor but I feel like the extra ~$50 of oil and filters is worth the extra peace of mind knowing that gunk is out of there.
dragosa
San Tan Valley
I just received the M340HV pump and for some odd reason when i enter the M360 it says it does not fit my vehicle.
Where did you purchase the new Roller Followers/Adjusters?
Joe S
Prescott Valley Arizona
Mine is a 2012 limited and it just got back from BSG automotive (FTM) and he installed the M340HV pump…he never mentioned the M360HV to me
dr2024
seattle
Awesome thread!
I did my family’s 2006 Expedition (5.4L 3V) several years ago, here are some additional thoughts -
Definitely hit FordTechMakuloco’s YouTube channel, he’s got actual walkthroughs that were hugely useful.
AlldataDIY subscription is a great resource for the factory repair manuals, and the timing processes are very particular.
Parts -
Freedom Racing has some great timing kits, I opted for all Ford/OEM that included a Melling 340HV oil pump. You might need a couple additional things like a new crankshaft pulley bolt, but the kit I got was generally very complete.
Roller followers and hydraulic lifters I sourced from Summit Racing (note, 5.4 and 4.6 take the same parts here, look for the most economical package, eg FMS-M6529-3V - search that, it should come up with a set of 24 roller followers & 24 hydraulic lifters).
OP’s #8 tip re priming the oil pump is absolutely correct.
Hydraulic valve lifters - I replaced all of mine, some separated leaving a hollow cylinder stuck in the cupped recess of the head. How to extract them?! -> I found concrete anchors at the hardware store whose outer (un-expanded) diameter closely matched the inner diameter of the hollow remains of the separated lifters, modified them to suit and they worked beautifully to remove stuck shells of the lifters.
Crankshaft pulley bolt - I ended up using the rope trick to hold the crankshaft. Pull a spark plug, put the piston before TDC of a compression stroke (or after, depending on which way you need to apply torque), feed rope in through the spark plug hole (I used braided nylon rope, soft), then rotate the crank till the piston snugs up against the rope. Think it through, be smart… plenty of rope, plenty of rope tail end, compression not exhaust/intake so don’t press on open valves (of course if the camshafts are off then all valves are closed), etc.
I would do the spark plugs at the same time, creates a good baseline. (Plus at the end when I did mine I found that the rear two on the drivers side were filthy and loose, creating much of the noise that caused me to do the timing set in the first place, though it did need a new timing set and runs like a sewing machine since).
Oil pan - I installed a new Melling 340 HV pump. Our Expedition has 4WD so I couldn’t remove the pan without also dropping lots of other gear.
BUT - I found I could easily drop the front of the oil pan several inches without removing any suspension or driveline components, and that gave enough clearance to carefully replace the oil pump. Ratcheting flex head box end wrenches were very useful there (and also with the steering pump bolts).
Oh… and, before you apply a puller to remove the crankshaft pulley/harmonic balancer, make sure to remove the thick washer that was behind the crankshaft pulley bolt. =]
dr2024
seattle
Note re Melling oil pumps -
FordTechMakuloco recommended Melling 360HV (he has a YouTube video or 2 on that) which is what came with timing set kit I got from Freedom Racing.
HV is “High Volume”, about 20% more than stock which is a Good Thing.
Difference between 360HV & 340HV is, latter has standard 60 psi pressure relief spring, former has 80 psi (which should be fine, that’s reportedly what the 4.6 Mustangs run).
Link to Freedom Racing timing set kit - Ford/OEM w/Melling
hanisba
