5.4l engine stuck at 300 rpm!
Discussion in '3rd Gen - 2007 - 2017' started by AccraBob, Jul 21, 2019.
  1. AccraBob
    AccraBob Active Member
    40
    20
    Aug 17, 2015
    New Jersey
    My 2014 Expedition has just developed its first engine problem after almost 96,000 miles. I guess I should feel lucky...but not so much. :)
    I had an oil change and 99 point check done at a local Ford dealer on July 11, and all was OK. That was followed by some suspension work and an idler wheel/serpentine belt change at the same dealer on July 19. All seemed OK, it drove normally until today (July 21) when I saw a severe drop in acceleration, and I had to pull into a vacant parking lot. The engine was idling at 300 rpm, and while I could pump the accelerator a few times and it would rev up to 3500 rpm, soon it wouldn't even do that - it just sits at 300 rpm idling rough, not enough juice to even move the vehicle, or fully power the steering and brakes. Accelerator pedal has no effect on engine speed though the "foot feel" seems normal. A few minutes later the check engine light came on. Doing the in-dash system check shows nothing wrong, gauges show normal. Now it starts, sits at 300 rpm, check engine light is on, but that's all it will do.
    I did fill the tank yesterday (it took 16 gallons out of total 26) but it was at a reputable gas station, and no problems until more than 24 hours later.
    Truck has been towed to the dealer that did the work in the past 2 weeks, though they are closed today. I'll be all over them in the morning, but meanwhile, anyone have some idea what might be going on? Never seen this before.
  2. JExpedition07
    JExpedition07 Ultimate Member Supporting Member
    4,167
    1,584
    Sounds like a Throttle Body issue for sure, update us on what it is. Should have had the codes pulled first.
    Trainmaster and iimagine like this.
  3. AccraBob
    40
    20
    Aug 17, 2015
    New Jersey
    Interesting...but what codes do you speak of?
  4. kyleaaronburkett
    kyleaaronburkett Active Member
    27
    34
    Jul 19, 2019
    US
    The check engine light would give a code when an OBD reader is plugged in. Whatever the code reads likely would hint more at the issue
    Sent from my moto g(7) using Tapatalk
    iimagine likes this.
  5. AccraBob
    40
    20
    Aug 17, 2015
    New Jersey
    Ah. I'll have to leave that to the dealer then. I do know Morse Code, but I don't have an OBD reader. Thanks.
  6. ManUpOrShutUp
    ManUpOrShutUp Full Access Members
    929
    297
    Mar 27, 2016
    Northeast
    For future reference, Advance Auto, Autozone, etc. will read the codes for free.
  7. AccraBob
    40
    20
    Aug 17, 2015
    New Jersey
    That is excellent info. In this case, the vehicle wouldn't move so it had to be towed, and the dealer who had just serviced it seemed to be the right destination. But next time I get a warning light and the vehicle is still mobile, I'll do what you suggested! Good stuff.
    kyleaaronburkett likes this.
  8. ManUpOrShutUp
    929
    297
    Mar 27, 2016
    Northeast
    It's probably their fault anyway. My wife had her Mazda serviced at the dealer awhile back. We picked it up after hours and drove it to the supermarket less than 5 miles away. When we tried to start it, it was dead and had to be towed to the dealership. Coincidence? No way. Ultimately, we discovered that the tech that worked on it never disconnected the battery while removing the dash. He fried the battery and blew over a dozen fuses. Never underestimate the level of incompetence out there. :p
  9. AccraBob
    40
    20
    Aug 17, 2015
    New Jersey
    Update: Just got back from dealer. Service consultant there read the codes and said there were a bunch relating to "oxygen sensor". I've asked him to send me the list of codes he read.
  10. AccraBob
    40
    20
    Aug 17, 2015
    New Jersey
    The codes were P2195 and P2197 and then they found a bug stuck in the mass air flow sensor. My Expedition choked on a bug?
    Sent from my LM-G820 using Tapatalk
Share This Page
