Ok finnaly got it out!!. on to the next set of problems. my friend forced the socket inthere and started to lefty loosey guessing at it and took out the socket and there was the damn spark plug. we used the endoscope to see where the tape and o ring whent and sure enough it was there, we tried to pick, drag, and claw tool it, and said whatever and blow gunned it, sure enough the tape came flying out. cylinder chamber saved. THANKS EVERYBODY.
it ended up being electrical tape with the o ring. i guess the previous owner tried to mess with it. smh. all the other ignition coils were loose. one of them was cross threaded inside the intake manifold?
so i guess in all this shuffle. i ended up loosing the PCV Valve Groumment and cant see to find it. i will do a search on ford parts.
also i found this T Shape Vacuum hoses that run to behind the battery box?? it was disconnected with a screw inside. and other side comming from the engine was taped off. my guess would be that box behind the battery is cracked?
would anybody have part numbers for the Groumment, Vacuum hoses, and that box?
