5 speed swap ????
TactialMonkey
Washington
i believe the zf 6 has been done in a f150 of the same year but honestly I see no gain to having the 6th gear as you will only use it going down hill I mean our trucks are so heavy the 6th gear is not worth the tunnel work when the 5 speed is a bolt in unless you want the granny gear then i see reason
hsquared360
