97-03 tow package
The Stinker
Tx
I could be wrong but I think the ones with the tow pkg have a higher total gross weight listen on the door sticker.
whowey
Illinois
My plug for the brake controller was on the same bracket as the obd-II plug. Directly next to it.
white7wolf
missoula, montana
Cool! :D not that ill be towing anything for a long time... But still cool to know that this can tow more then the 99 dodge half ton i traded it for =D
Sent from my galaxy s3
RedDragon777
RedDragon777
I was looking at summit racing and found two different Rads for the Expedition. One was a single core the other was a 2-core rad. Which would be the equivalent to the rad that Tow package expys come with? Also anyone have a better Rad to replace my factory one with, i know Mishimoto is making one for the Lightning but i do not know if it will work with my Expy?
Boatright92
California
from my build sheet.
Towing Package:
2" receiving frame hitch (recall to upgrade bolts in '99/2000)
7-pin connector
Transmission cooler
Electric brake wiring underneath center console
LS rear diff
PanHandler.
Is that the actual build sheet or a window sticker? And if it’s an actual build sheet not a window sticker where did you happen to find it?
