TheWildMechanic
Hi, I've got quite the electrical goblin hiding somewhere. Anyone have any suggestions?
So, lemme back up. I have a 99 Expie EB 5.4, with the 4R100 transmission in her, and I have the locked in 4WD (A4WD, 4H, 4L). So, couple weeks ago, I played with my switch, nothing happened, drove home, then on my last turn to get home, something made an expensive noise. I believe my River got shifted into 4L without me touching my switch. She was in A4WD. So I tore my rear diff cover off to make sure I didn't blow the axle, and that diff is shiny as ever.
Then she magically fixed herself, got out of 4WD and was chilling. She did throw a P1838, and so I took it into my shop at DATC, and we found no power at the motor KOEO, but I've also been able to shift it KOER and hear it just fine, always in Neutral when shifting. Then she got stuck again and got grounded. So I left her at the shop, got my part and didn’t touch the switch until we went to fix it.
When we put the motor in, we noticed that the front t-case speed sensor was bare copper on all three wires, so we got a new one, same with the rear, (P/N SW5645 and SW5644, for anyone else needing those, that was a struggle to find). I accidentally put both rear sensors in, whoopsie, and she threw the P1838 and a P1867. We put the right sensor in, and still just a P1838.
Now we get to the icing on this lovely cake of electrical. Now, in A4WD, she refuses to get out of 4L and locks my wheels when turning, aka, how 4L and 4H operate. We've done live data and the clutch is goin to 38% at like 5mph, when it should be 1%, like what we saw before the goblin came in. We're tearing into my dash to check the relays and soldering on the board. I can't find a part number for the relay itself, and I also can't find any other information on this issue relating to the code and the issue other than T-case motor repair.
Any information is absolutely appreciated, as my poor girlie has been stuck in the shop for over a week now.
Thanks! - Wild
Thanks! - Wild
