A/C always on when I start
coastryder
Coast Guard Navy
Greetings all!
Purchased a 2027 20th anny edition a couple months ago. My A/C is coming on every time I start the car, regardless of what I had it set to when I turned it off. I've looked through the online manual, searched online, can't find any way to not have it automatically come on every time. Has anyone else encountered this or found a way around it?
TIA!
99WhiteC5Coupe
Greetings all!
TIA!
Perhaps contact your vehicle salesperson to determine how to turn-off the feature?
dlcorbett
Air Force
tx
Is it cold out when you start the car or warm? Is there condensation on the windows when you start?
IQIHUI_Auto
Ningbo, China
On the 4th/5th-gen Expedition climate control module, there are two common reasons the A/C compressor indicator defaults to ON every key cycle:
  1. Defrost / Floor-Defrost Blend Door Position: If the mode door is left in Defrost or Mix, the HVAC module automatically commands the A/C compressor on to dehumidify the cabin air, and on certain firmware versions it illuminates the A/C button on the next startup.
  2. Remote Start Climate Settings (IPC Menu): Check Settings → Vehicle → Remote Start → Climate Control—if it is set to Auto instead of Last Settings, the BCM/HVAC module will often initialize with A/C enabled whenever ambient/cabin humidity sensors read above threshold.
Staff online
Al_Harley
