JacobGG
I've got an 06 limited and the a/c hasn't been blowing cold. The compressor clutch wasn't engaging, so I checked the fuses and the relay and I found that the relay wouldn't click when the a/c was turned on or off, I took it out and tested it but the relay worked so I can only assume that it isn't getting any voltage. If you know what might be causing this I'd appreciate it if you'd let me know.
