MobilTech86
Okay so I have been chasing this A/C issue, I get mixed air out of the vents front and sometimes the rear , the things I originally did because the compressor before left to another life….., A/C compressor, condenser, expansion valves & A/C flush through lines and evaporators so just about everything, after this I had a cool and warm air deal that I couldn’t figure out at first I assumed maybe the blend door actuator wasn’t working as it should I tried multiple attempts at correcting the issues but nothing seemed to solve it I even went as far as hooking up my autel and reading all my data from the sunload sensor to the compressor it self and just couldn’t hack it , then one day I saw a video of a guy cleaning his evaporator through the resistor opening so naturally I got curious!! When I removed it I stuck a bore scope in the opening and lord !!! Was the evaporator clogged like hell , I grabbed a can of evaporator cleaner and got to it, even got a air gun inside and blew most of the crap out after a hour or so the evaporator was clean I turned on the truck and let the A/C run and my issue of the mixed air and short cycling compressor was solved , I drove home from work in comfort. So maybe check your evaporators if you didn’t replace them and see the condition before replacing or shooting the parts cannon at it .
