A/C trouble
R
RWheelihan
Florida
I have checked and ohmed the wires going from the coil connection to the pin that actually inserts into the computer for that cylinder. They are good. I have signal all the way through the positive and negative wire going to that coil.
R
RWheelihan
Florida
So I found that the signal wire going to the coil was indeed broken and would occasionally make contact and that’s why it would ohm out good but sometimes wouldn’t. anyway I went to ford and got the replacement plug to the coil and spliced ig in. All good now and the A/C is running just fine and no stumbles or engine code.
Sorry for the long time passing since I posted, I had an emergency appendix removal. Thanks everyone who assisted with suggestions.
