Good info, thanks! Have you ever had experience with or tried Duracool? I've read that it about as good as R12 and is compatible with R134a oils. I know it's more flammable and such but again, just curious.
Yes I have a case or so here now.
Almost all of those regardless of name are HC blends. Hydrocarbon blends.
They are a real hush hush kind or gray area don't ask don't tell thing.
They barely get by with legally selling them and the safety freaks don't help matters any.
You can buy them for cars and for houses...like HC22.
Rural King sold some 30 lb (or equivalent) jugs a couple of years ago and probably still do.
They are compatible with PAG oil or 134a and will lower duct temp.
I got 8-10 degrees on same day in exact same conditions after swapping one over back in 2008.
I can't say what the real world long term durability for compressor is and if if it does leak any and gets low, due to being blend and leaking at different percentages etc, you are supposed to evacuate and recharge. You also charge as a liquid only! (as far as I know)
With compressor quality nowadays (or lack thereof) I don't really think it matters.
The fear mongering (and yes I've seem the Porsche video that catches on fire) of a leak going to burst into flames is WAY overplayed.
Cars do burst into all the time! But the percentage is super low. There are a lot of cars in the world!!
Gasoline leaks cause a lot if not most of these fires...and ones that are not "started" by gas leak are often electrical or at first massive overheating which either causes wires to melt and catch fire or melts fuel lines (gotta love those plastic flexible quick connects they have under hood) and then the gas is what really flames!
AC refrigerant leaks are s-l-o-w. Any leak that is faster than that will be all gone in less than 3 days so there will be none left to be flammable.
I have an 05 Saab now that leaks out in two days. Filled it once to see and haven't bothered since.
Here's the dealbreaker for most. They are usually a butane propane mix or isobutane propane mix. ---hear the gasps now....
Now remember the new z1234 or whatever it's called is also flammable.
R134a wasn't considered flammable but new is so I don't know to what degree we are talking but it is more since it IS flammable.
So much so that I think it's Mercedes that for now is refusing to use it and I read they cite flammability possibility.
So you really have nothing to lose but some time and a few bucks if you want to try a HC replacement. I definitely got colder vent temps on a challenged system.
Do a search for drop in replacements.
I think even Johnson had one but not HC. I think there were/are some azeotropic blends of different refrigerants that give better results than r134a.
