Andy Rubalcaba
Thank you for discussing! Yes I have a new crankshaft bolt in my cart, I have pretty much picked every single little part that I need for the job, and am spending about 3 grand in parts and some tools ( some are specialty, and a few are just bits and pieces of tools that I don't already have, but it's mostly just the ford parts and such ). I'm replacing everything brand new except the camshafts, those I will wait and see how they actually look. but the rollers, timing kit, fuel pump, all the gaskets and now these iron tensioners, new spark plugs and new ignition coils ( mine have red ones so I think previous owner replaced with aftermarket, so those have got to go ), new battery, pretty much following FordTech's video to the T!Andy those are good to go. I used 'em in mine and they've been bulletproof. It's what Ford use to use before the accountants stepped in. You'll need the new Crankshaft bolt as well, since they are "torque to yield" tightening specs. I used a black impact socket and took a silver Sharpie and drew lines 90 degrees apart on the socket (i.e. 4 lines ...). Used an air impact to spin it the required 90 degree torque turn.
I can't wait to get started, but also nervous cause i've never done a mechanical DIY job this big before. tax money should be here in another 2 weeks so this project is just around the corner
