Abs and traction control light on 06 Ford expedition
bwean
Pittsgrove nj
Any advice would be great. 2006 ford expedition 5.4 165,000 codes p0732 p0700 p0846 p0733. The abs light is on. The engine will rev but will not move then traction control will disengage and it will run fine with abs light and traction control lights staying on.
I would really appreciate any advice. Thank you
Hamfisted
Ft Lauderdale
Have you checked the fluid level with the engine running and warmed up ? Those are tranny slipping codes. Are you the original owner ? If the fluid level is correct is it bright red ? Or brownish? Bright red is good, brown is bad.
B
bwean
Pittsgrove nj
Yes I have. I am the second owner but the car fax shows it was taken care of. I changed to trans fluid and filter about 6 months ago. When traction control is off it shifts great. I was hoping it would be a speed sensor or ABS module.
Hamfisted
Ft Lauderdale
Well the P0846 code is a pressure switch indication of out of spec line pressure. That probably caused the PCM to put the tranny in Limp mode. If you're not comfortable working on transmissions it's probably best to find a reliable shop in your area that can take a look at it.
B
bwean
Pittsgrove nj
Unfortunately I am not if it's inside the transmission but if its outside I will definitely give it a try. I will try and Google the location after work. Thank you very much
