ABS Codes: C1165, C1235, B1676
Hoos95
2007 EL 357K
ABS light came on. Scanner came back with the following codes:
  • C1165: Right Rear Wheel Speed Sensor Input Circuit Failure
  • C1235: Right Rear Wheel Speed Sensor Input Signal Missing
  • B1676: Battery Pack Voltage Out Of Range
Before I take it into the shop, wanted to see if anyone has had experience with these codes and to see if I can fix myself.
Appreciate the help!
erickperez
Panama,Central America
2007 EL 357K
Hi, did you ever find a solution? I have the same codes but on a 2010 EB 2WD @Hoos95
AWAR
oregon
The OP has not posted since 2023, so I doubt you will get an answer. I could be wrong, did you look at the wiring for the right rear ABS sensor?
