AC CLUTCH RELAY FOR FORD EXPEDITION 2003 MODEL
StibbyWonder
Philippines
Good day Exped fam!
Hi my AC relay (F0AB-14B192-AA) located in the box front driver side near the head light is busted and my AC compressor is not clicking. I already checked all the AC related and it’s working fine. Now, my problem is I bought online a Ford relay with F0AB-14B192-AA code in it bur they delivered a Jaguar/Landrover relay with code DH22-14B192-DA. I am not sure if this one will fit.
It has a 5 pins as well. I checked the diagram it is different from Ford. Here is the picture of the relay from Jaguar/Landrover I received.
This is from Jaguar/Landrover
This photo below is from Ford Expedition that supposed to be delivered to me.
Do you have some advices for me if Jaguar/Landrover can fit and will work fine?
Also if you know an online store that sells same with Ford and original one that can be shipped in my country, The Philippines.
Thank you so much guys and more power to you all!
whtbronco
Winchester, VA
Best I can tell the F0AB-14B192-AA is a 5-pin 30-amp relay. The DH22-14B192-DA is a 5-pin 40amp relay. So it should work, but is rated higher than stock which it not a huge issue so long as the fuse remains the correct size.
StibbyWonder
StibbyWonder
Philippines
Yes, I already tried it and install the relay and it works. My compressor already kicked in and rotating. Thank you bro.
