AC clutch
E
Enigma346
Hertford, NC
I don't know my pressure. Compressor won't kick in. I don't have gauges either. Only gauge I have is the one that comes with the refill cans you can buy at AutoZone . And those only fit the low side
Big Brian
Farmington Hills Mi
that's all you need. Screw it on and see what it reads. Hi side is only used for diagnostic purposes
unless you mean the gauge is built into the can? I have seen those but I have never used one. Probably should still work but I am not sure. I have one that built into the low side hose for recharging like this
https://www.amazon.com/Certified-R-...5456680&sr=8-3&keywords=ac+recharge+kit+r134a
johnboneske
Ohio
No...that's not right. If the compressor isn't running, low side ALWAYS shows very high. Always over 100. High side shows lower. If he connects a service hose to the low side and tries to ad refrigerant, the compressor will kick on in about 5 seconds if it is just a charge problem. The dual Units(front and rear a.c.) hold a lot more refrigerant than the single units. I think mine is 54 oz. Don't forget PAG oil too. Don't forget you can only check pressures when its running...
Big Brian
Farmington Hills Mi
It could read 100 depending if the vehicle was recently running, if its hot under the hood or its hot outside lots of variables
My point is if its reading 10psi for instance then he knows its low on 134a and that has to be addressed before anything else
that's all I am saying
johnboneske
Ohio
Sorry...I standTemp-pressure-chart-33776F1.jpg corrected then!
Here is the omly chart I know of...LOL
johnboneske
Ohio
I mainly do Home HVAC, and do my cars and friends cars too...learn something everyday!
Big Brian
Farmington Hills Mi
It's all good dude I made my living as an auto mechanic for 20 years even though some on this board claim I don't know what I am talking about I just ignore them and try to help out when I can
E
Enigma346
Hertford, NC
hsquared360
