Dustin Gebhardt
If the AC works fine while moving, but struggles while idling, then I would say that the condenser is struggling. The AC on my '07 make's 70'F air (center vent, driver's side) when idling in >90'F ambient weather or makes 50-60'F air while driving in town. But when I'm driving for several miles, the AC temperature drops below 30'F. I figure that the condenser cannot shed enough heat when the car isn't moving. I plan on adding a push e-fan in front of the condenser and transmission coolers to help with this issue.
I should also mention that I added a resistor across the temperature sensor for the evaporator/blower (located behind the glove box). I don't recall the exact value, but I think it is around 300K ohm. This causes the system to think that the evaporator temperature is higher and runs the compressor longer. I did this because my compressor was cycling on/off when the sensor was reading in the 50's and 60's (center vent temperature). Now the center vent will get down in the high 20's on a mild day when driving on the freeway. It occasionally will ice up, so I think I need to change the resistor to something higher (maybe 330k ohm or 360k ohm). This takes all of 5 minutes on my '07, but YMMV.
