Added USB-C Charger
iamretired
Pahrump, Nevada
My 2015 has 12 volt plug and cubby thing on passenger side also. Any advice on taking that panel with 12 volt plug and cubby thing off?? Hoping not to deal with airbag panel. I want to run power from 12 volt plug to top of dash, since I was able to get center tray out of the dash, which is not screwed in like the ones that have the speaker in center of dash.
T
TXFRDOwner
this is a good start, removing the control panel gives you more room to work and allows you to see behind the 12V socket
T
TXFRDOwner
Do you have the part number for the 400w f-150 connectors (orange or yellow and 3 blacks) that you wired in to the wpt-396 expedition pigtail?
3 blacks ?
T
TXFRDOwner
[emoji2] oh it’s only one black connector
I’ll dig up the information
UPDATE:
F150 (400W) Inverter
1 - Motorcraft Pigtail P/N: WPT-1330
2 - Connector: TE 1452203-1 (Qty: 1)
0.64mm (F) Terminal: TE 1719958-1 (Qty: 3)
6.3mm (F) Terminal: Yazaki 7116-4124-02 (Qty: 2)
F150 Dash AC Outlet
Motorcraft Pigtail P/N: WPT-962
Expedition Rear Panel AC Outlet
Motorcraft Pigtail P/N: WPT-1006
