AGM battery
Bmac1955
Southern Cali
Has anyone here ever checked the resting period of a Motorcraft battery on their Expedition. Mine generally shows 12.2 to 12.4 after a 10 hr period of not driving. I have trickled charged it on occasions at 10 volts for about 4 hrs and it goes up to 13 volts after charge but settles down to
12.4. Battery 2 years old and this question is
mainly out of curiosity. I do realize a few electronics are running in the background.
LazSlate
Arizona
Batteries are weird. Supposedly 12.6 indicates a fully charged battery and 12.4 is discharged and 12.0 is supposedly dead. (got these numbers from a car battery consortium) Depending on where you live most batteries last 4 - 5 years max.
The best way to really know is buy one of those digital computerized battery testers. They give you a ton of info about the battery.
I got one for $50.
For now I would not worry if it stays at 12.4 but would keep an eye on it every few months.
lobsenza
I put my battery on a trickle charge overnight about once per month. This extends battery life.
Expy Gator
Florida
Most modern cars have a resting demand on the battery - if you are not driving for several days at a time I would invest in a battery maintainer. I have several CTEK maintainers - and have batteries lasting 10 years. Many top manufacturers use rebranded CTEK units - I would advise you to visit the CTEK website and learn about the chargers and different charging profiles - AGM is different than regular lead acid.
Hyins
Santa Clara
Charging System
The PCM controlled Smart Charge charging system determines the optimal voltage setpoint for the charging system and communicates this information to the voltage regulator. The Smart Charge charging system is designed to set a DTC when a charging system fault is present. All of the DTC can set continuous faults, but not all DTC 's set as on-demand faults.
The smart regenerative charge system primary strategy is stored in the BCM . The BCM receives information relating to the battery condition from the battery monitoring sensor via a LIN . The BCM calculates and sends the set value needed for the generator charging voltage via the HS-CAN to the PCM . The PCM then adjusts the value received (if necessary) and sends it to the generator via a different LIN . The charging voltage is adjusted depending on various parameters, such as the current level of engine efficiency. The smallest possible set value for the generator voltage is 12.2 volts, while the maximum charging voltage can be anywhere between 14.5 and 14.9 volts. However, when the battery is in a refresh phase, the voltage may occasionally reach up to 15.2 volts. These refresh phases are required when the battery charge status is 80% over long periods of time, which increases the risk of sulfation in the battery cells.
The PCM simultaneously controls and monitors generator output. When the current consumption is high or the battery is discharged, the PCM raises engine speed as needed to increase generator output. The generator charges the battery and at the same time supplies power for all electrical loads. The battery is more effectively charged with a higher voltage when the battery is cold and a lower voltage when the battery is warm.
The PCM turns off the generator during cranking to reduce the generator load and improve cranking speed. Once the engine starts, the PCM slowly increases generator output to the desired voltage.
The PCM reports any charging system faults and sends a message through the HS-CAN to the BCM . The BCM then sends a message over the MS-CAN to the IPC , which controls the charging system warning indicator. If equipped with a charging system warning indicator, the IPC turns the indicator on or off. If equipped with a message center, the IPC displays the corresponding message to notify the driver of the condition.
Under certain circumstances, the charging system may have a concern but still keeps the battery charged while the vehicle is running. The LIN is normally used to initiate charging, but with a fault in this circuit the generator self-excites or begins charging on its own. The charging system warning indicator is illuminated and/or the corresponding message to notify the driver of the condition is displayed and the generator operates in a default mode (approximately 13.8 volts).
Electrical Energy Management System
NOTICE: When any vehicle module is being programmed, connect an external battery charger to make sure the module programming is completed without interruption due to the load shedding feature becoming active. The external battery charger must maintain a system voltage above 13 volts. This may require a charger setting higher than the lowest charge setting. The external battery charger negative connection must be made to an engine or vehicle chassis ground and not the negative battery terminal. If the connection is to the negative battery terminal, load shedding may begin and module programming may be corrupted. After charging has begun, start the engine to clear any load shed states and then turn the engine off and proceed with programming.
This vehicle is equipped with an Electrical Energy Management system which manages battery charging and monitors the battery state of charge. The Electrical Energy Management system also utilizes a load shed strategy to help control discharge of the battery and prevent, when possible, an excessively low battery state of charge. The BCM uses a battery monitoring sensor to monitor the battery state of charge.
To maintain correct operation of the load shed system, any electrical devices or equipment must be grounded to the chassis ground and not the negative battery terminal. A connection to the negative battery terminal causes an inaccurate measurement of the battery state of charge and incorrect load shed system operation due to the current being used bypassing the battery monitoring sensor. Refer to the Battery Monitoring Sensor component description in this section.
Battery State of Charge
The Battery monitoring system monitors the battery current flow and voltage to determine the battery state of charge. During the drive cycle the the battery monitoring system software monitors the charge and discharge current and increases the charge during charging, and decreasing it during discharge. During rest periods (key off with no electrical loads) when the vehicle enters sleep mode, the battery voltage is sampled to calibrate the state of charge. The sensor automatically executes this calibration anytime the vehicle enters sleep mode and when the total vehicle current draw is below 400mA. It takes 8 to 10 hours in the sleep mode to calibrate the battery state of charge to high accuracy. If the system draw does not allow the battery state of charge calibration over the previous 7 to 10 days the state of charge quality factor changes to flag this and some the battery monitoring system functions, which rely on the accuracy of the battery state of charge, may be temporarily turned off until a calibration takes place.
Engine Off Load Shed
When the ignition is in ACC or ON mode and the BCM determines the battery voltage or the battery state of charge has dropped below set levels, a low battery warning message is displayed in the message center. Should the battery voltage or the battery state of charge continue to drop, the audio system is powered down to save the remaining battery charge. This load shed state clears once the vehicle is started and battery state of charge is allowed to recover.
When the ignition is in the ON mode and load shed occurs, the message center displays the corresponding message to notify the driver that battery protection actions are active. The audio system shuts down after the message center displays the warning.
If a fault occurs with the battery monitoring sensor or circuit(s), the only engine off load shed strategy that is active is a 45 minute timer. After 45 minutes have elapsed, the audio system turns off. To clear the load shed state, restart the engine.
Engine Running Load Shed
When the BCM and/or PSCM voltage is low, with the engine running, a message is sent by the BCM to either minimize or shut down the climate controlled seats, rear defrost, heated mirrors and DATC blower motor to improve system voltage. Under this condition, the IPC message center displays either LOW BATTERY LESS FEATURES (base message center) or Electrical Power Saver Active. Some Features Turned Off See Manual to notify the driver that battery protection actions are active.
There are 3 states of engine running load shed:
Load Shed StateEntry ConditionsImpact to FeaturesClear Conditions
Load shed 1If power source (alternator/DCDC) is fully saturated in combination with low battery voltage and low battery SOC.These loads are incrementally reduced (if equipped): Heated steering wheel and climate controlled seats. These loads are turned off (if equipped): smart trailer tow battery charge, heated mirrors, any climate features.Power source no longer saturated and battery voltage has recovered.
Load shed 2 transientPSCM indicating reduced voltage and increased current. System voltage less than 11 volts.
  • If equipped, climate controlled seats are disabled, but the indicators remain illuminated.
  • If equipped, rear defrost and heated mirrors are disabled, but the indicator remain illuminated.
Voltage to the BCM is greater than 12.5 volts.
Load shed 2 continuousLoad Shed 2 Transient conditionpresent for up to 60sec.
  • If equipped, any climate features are disabled and indicators are off.
  • If equipped with DATC , the blower motor is reduced to 50% speed.
  • If equipped, DC/AC inverter (AC powerpoint) is disabled.
  • The IPC message center displays "Electrical Power Saver Active. Some Features Turned Off See Manual.
Voltage to the BCM is greater than 12.4 volts for more than 60 seconds.
Battery Charging
NOTICE: If the charger is incorrectly connected to the battery negative terminal, DO NOT reset the battery monitoring system using the diagnostic scan tool. This reset is reserved for new battery installation only. This reset will clear the learned battery data, the battery time in service, and will affect the aging algorithm parameters, which have been learned since the installation of the battery.
The battery monitoring system will recalibrate itself after 8-10 hours ignition off.
When it is required to charge the vehicle battery, connect the positive connection to the battery positive post, and place the charger negative cable to vehicle ground. Do not connect the negative charger cable to the battery negative terminal. Connecting directly to the battery negative terminal bypasses the vehicle sensors, not allowing the BMS to detect the charge current. As a result the battery state of charge does not reflect the charging. Look for the body ground cable coming off the clamp or the battery monitoring sensor and try and connect in this location (typically on the shock tower sheet metal).
If the battery is being charged due to a load shedding message, only properly charging the battery assists in clearing this message. If the charger was properly installed, the BMS system calibrates the battery state of charge after about 8 hours.
shane_th_ee
Seattle
Note that the Expedition will enter a low power mode if it sits for an extended period such that the battery is drained below some preset level...
zak99b5
Albany N.Y.
From the factory, the car is set to charge the battery to 80% of capacity. You can change this with forscan.
