Am I pushing payload capacity too much?
Jason Bell
Kansas
For those of you that are in the same situation - but mine is rated for a lot more payload that you guys are quoting. I'm guessing it's the trim level and options? Mine is XL, (below XLT) 4x4, 3.73, and heavy tow. Sticker says cargo weight of 1850 lbs. Yes, I give up a lot of fancy options, but I prefer the simplicity and increased payload. Sounds like the extra 200-400 lbs of payload would make a big difference in these loadings.
2020ExpyPlatinum
Cleveland, OH
Reading through all the posts, it seems a lot of you really question whether or not you are overloading your rigs or to close to the maximum.
I go by the 80/20 rule. If it's not a super long trip I may push it a little higher.
Maxing out on the ratings will not only cause your brakes, transmission and driveline to wear out faster, it is also dangerous.
Knut
Each to their own.
However, if the numbers posted by FORD was dangerous, I highly doubt they would have certified it and much less posted these numbers for liability reasons.
Does it create more wear compared to a lighter trailer or no trailer? Off course it does.
But don’t tell me they post numbers they are not confident with or have done their due diligence to test out. Their own Legal department would not have let them.
2020ExpyPlatinum
Cleveland, OH
Each to their own.
Yes ford posts a maximum tow rating and a maximum payload. When you approach the maximums you are stressing the systems that were engineered.
When you use overhead lifting equipment and straps / slings, you don't pick the smallest strap rated at the same weight as the object you are lifting.
Our ford expedition could probably tow the space shuttle with relative ease, stopping it would be a different story.
If you want to max your rig out and not leave any margins for safety that is your choice.
All I was simply saying was if you are debating whether or not you are maxing it out, you probably are and needed a bigger vehicle in the first place.
At the end of the day you are limited to the axles and how much weight they can support.
duneslider
Utah
What model trailer is this? I don't see it at all on Jayco's website but the weight seems really high to me for that trailer? I have a similar hybrid trailer (Rockwood Roo 23) but it doesn't have that gear deck up front (I would love to have that though!). The heaviest jayco hybrid is 6150# GVWR, I can see how they could add some extra payload weight for the 3' deck but adding an additional 1300# seems like a lot! Seems to me at 7500# that trailer is heavier than the manufacturer calls out. Curious if you have some sort of special package on it or something. The rockwood 233s has a max loaded weight of about 6700#
Utah Driver
Utah
You could go with a front mount hitch and put the bikes in the front. Only if the bikes are not high end because of bug splatter. Also put bikes on the roof. It's a pain but doable. Cheers
Tyra
minnesota
Question. I am getting a 2022 limited with SPP and heavy duty tow. I am wanting to get a travel trailer and the ones I have been liking are around 32 - 33 ft. They are well under the weight limit fully loaded but I have some people telling me I shouldn’t get one that long because of the shorter wheel base on the Expedition (I didn’t get the Max). Recommended I stay under 30ft Any comments, concerns, different opinions, advice?
Squark
NC
2018 Max Limited owner here, with the HD tow package and a 33’ travel trailer. I also use a ProPride hitch, LT tires, and Bilstein 5100 shocks. I’m looking for a heavy duty truck. In low traffic and low wind, it tows great. But add passing semis and a stiff crosswind, and it’s uncomfortable. By that I mean I’m constantly getting bumped around and having to work to stay centered in the lane. I’ve pretty much always felt in control, but it’s tiring and feels like I’m really pushing the limits. For me I think the length of the trailer is a big factor. It’s a big sail. The engine has plenty of power for the weight (7,600lb in my case) and I haven’t had any issues braking.
It’s possible to do what you’re asking, but I would personally go with a smaller trailer or a bigger truck. That’s been my big dilemma. I want a bigger truck so we can tow a larger camper, but my wife doesn’t want to lose our family road trip vehicle (which the Expy is perfect at).
Tyra
minnesota
What what is the max length you would recommend? I found a few about 28 - 29 ft that I could deal with. Not sure if that is still to long? I really don’t want to go much shorter than that. I will say I really do not have any experience in towing other than a small open utility trailer. I want something with a separate bedroom and a decent kitchen and a comfy place to sit/watch Tv. Also be able accommodate another adult sleeping space for when I want to bring a friend.
JasonH
Houston, TX
Try renting and see how it feels. I have a long wheelbase and my camper is ~33 ft. Even though it tows comfortably, I wouldn't want to go any larger. I honestly couldn't imagine being comfortable towing this size with the short wheelbase.
