Android auto problem
Timmaaay4
Apparently today while my wife was on a trip Android Auto and the radio stopped working. The only volume that would work on the car was the voice prompt for volumes. She pulled over turned off the car and started it again and the radio started to work as normal however The USB ports in the front are not powered any longer. Any one else have anything off with the head unit
Sent from my SM-G970U using Tapatalk
Anthony DeVor
Maryland
Thats nothing neq with mine. You just have to unplug the phone and plug it back in or close the audio application and reopen it - it does it to me in carplay all the time.
TheDoug
Mansfield, TX
I had that issue a few times before I updated the ford sync software. On the latest version I have not had it happen yet.
Also one time the problem was my cord. I swapped it to the one that came with my phone and it worked better.
T
Timmaaay4
The front ports stopped working also?
I won't be able to look at the vechile until my wife gets back tomorrow, I am thinking maybe a fuse is blown?
5280tunage
colorado
Not sure why the ports would have stopped working, but make sure you first try the full reset twice in a row. See if that helps anything. Also make sure the phone is rebooted, I've had issues where AA keeps running and causes issues. But the latest version of AA and 3.4 seem to work pretty well.
TheDoug
Mansfield, TX
Oops... I must have missed the part about the ports not being powered when I posted previously.
Should just be a fuse.
Johnb21
boston, ma
My top port randomly stops working, more times than less. I often hear a loud click ( like the sound of a circuit breaker) around the HVAC area. The click has been going on for a couple years, most often when I have the HVAC heat on (during colder weather). I don't know if the USB port is related to the clicking, as the top USB has only been an issue for the past 6-9 months. Turning the truck on/off has worked to reset the USB in the past, but less so now.
My issues are mainly with the top port, but have seen both ports go out as well. I didn't want to bring it to the dealership to have them send me home because they couldn't replicate the issue. Next oil change, I will have them look at it.
Any thoughts are appreciated!
T
Timmaaay4
Apparently on my wife's drive home the ports and Android auto started working again. I am assuming that shutting off the car reset sync as described. I did however update sync yesterday to the latest version of sync 3.0 . No issues as if yet will keep an eye on it. Tha ks for the help
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Apparently on my wife's drive home the ports and Android auto started working again. I am assuming that shutting off the car reset sync as described. I did however update sync yesterday to the latest version of sync 3.0 . No issues as if yet will keep an eye on it. Thanks for the help
You should be able to go to 3.4, and it will have WAY less issues, and is a little quicker.
CyanLabs.net, and find the Sync updater app, install it, and follow its instructions.
