Progress on the 04 EB, I am fixing all the little stuff. I tested the 4x4 module by swapping a known good one from my 03 Navigator. The module works fine in the Navigator and the Navigator module acts just like the Expedition module in the Expedition. Reinstall both modules in their original rigs. I replaced the transfer case motor assembly and the Expedition now has working four wheel drive. The 4wheel high light only works on the initial bulb test but the 4wheel low light functions as it should. Good enough for now. I replaced the defective multifunction switch with one from inventory and also repaired the broken wires for the overdrive cancel function. Little tiny wires broken about a half inch from the harness connector. We replaced shift levers for broken wires and worn shifters all the time on the 90-03 Ford trucks.
Replaced the passenger mirror assembly that was broken and held together with tape and a zip tie. The puddle light came on when I connected the mirror. There is hope for the interior lights, none were working when purchased. I dropped the overhead console to repair the lights and found the sunroof wires disconnected. I hadn’t looked the the sunroof and that means that it doesn’t work properly. I looked at the outside and someone had urethaned it shut. I cut the urethane and plugged it in. The mechanism is screwed, it only moves on one side. I have another complete sunroof assembly from my 06 Navigator. So the headliner is out and the Navigator sunroof is in. The rear drains were clean and both front drains were plugged solid. I now know where exactly those drains end and how to clean them. I used compressed air, my shop vac and a long speedometer cable insert.
