1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
ATB ...
Discussion in '3rd Gen - 2007 - 2017' started by Flight-ER-Doc, May 6, 2021.
  1. Flight-ER-Doc
    Flight-ER-Doc Full Access Members
    65
    100
    31
    Nov 4, 2016
    Montana
    A few weeks ago I was driving, and my '15 Expy with 90k miles started misbehaving - CEL, no power etc...
    So, I coasted into a parking space, shut the engine down, and after a bit tried starting it up - started, ran OK for a minute or two, but no power when I tried to drive....
    Shut it down and started cancelling appointments for the day, getting coverage at work etc.
    Before I called for a tow, I started it up again, and was able to drive - with the CEL and MIL illuminated...just a few blocks from home, still under extended warranty, etc. When I got home I got out my ODB-II scanner and it said P2112, and the TSB for it said replace the ATB.
    Well, OK. $135 for an OEM ATB at Rock Auto, $4 for the gasket....Checked YT and it doesn't look that hard. So, I cleared the code.
    Now, the error has not reappeared. Not sure if that is good, or not.....
    Suggestions or comments?
  2. justinp16ex
    justinp16ex Full Access Members
    74
    22
    Nov 30, 2020
    Wisconsin
    Did the CEL flash and then stay on? Could be oily fluid in your intercooler getting sucked into the throttle body, might just need cleaning and get the fluid out of the intercooler somehow. The 15's had more of an issue with condensation in the intercooler, was supposed to be somewhat corrected on 16 and up.
  3. Flight-ER-Doc
    65
    100
    31
    Nov 4, 2016
    Montana
    Could be, I haven't been driving it much at all lately (haven't bought gas since Feb)..
    I'll try cleaning it out. Thanks!
  4. justinp16ex
    74
    22
    Nov 30, 2020
    Wisconsin
    Maybe it's not liking your old gas. Could be a good place to start.
  5. Flight-ER-Doc
    65
    100
    31
    Nov 4, 2016
    Montana
    It's only been two months....But I'll fill it up, too.
    Thanks
  6. os1kne
    os1kne Well-Known Member
    48
    45
    Jul 30, 2016
    Atlanta
    Any luck? I'm betting fresh gas and cleaning the throttle body solve most of this. Good luck!
Share This Page
