wakeboarder
I reloaded the original forscan backup files that I saved prior to making any changes, I also confirmed those settings with the factory settings i received from the Ford website. I then changed them so that the lincoln style fold still worked. Before I did that I tested it and it was still messed up.
I did use the settings listed in the Forscan tools (changing the first characters to "F's" to enable the reverse tilt feature, guess I didn't even try it prior to that, but the calibration setup is a pain and to be honest, if you're only going to get one mirror at a time, and it only works if that mirror is selected, then it's kind of a waste. Let me rephrase that, coming from a vehicle bought in 2010, that had a fully functioning reverse tilt function, that is, every time I put it in reverse, both mirrors would tilt, this seems pretty lackluster.
What other Forscan tweaks did you attempt? Since things are reversed, do you think there is any possibility that you inadvertently enabled right hand drive? Have you tried reflashing the rest of the modules you have modified to the backups?
