6th generation Ford owner.
2001 Ford Expedition, T-boned in rear right quarterpanel by van in mid 2020. All-State denied responsibility of their driver so haven't fixed the damage.
Power driver window function important.
Problem: when fuse 14 is removed, no windows, etc, and battery doesn't drain. But keeping fuse 14 installed and turning off vehicle drains battery in short time..Unless, disconnecting the battery at every ignition turn off.
Question: What is the electrical route of that circuit through that rear right quarterpanel, so that I might reroute/reconnect it if pinched somewhere? I'll run it inside the vehicle as necessary.
Thank you.
Thank you.
