Driver's
Driver's floor mats were pretty close to what I'd hoped for. Higher sidewalls, full coverage on the foot rest and full coverage under the accelerator.I do wishit came a little further under the seat and right up to the driver's seat tracks, but this is still much better than the OEM mats we had.
Front Passenger
The story on the front passenger side is much the same. I think the coverage could be slightly better. I wish it ran higher up the front wall of the footwell here and also provided better coverage on the side kick where you can see someone has already gotten it dirty. Still this is loads better than the OEM Ford mats and much better fitting. Interestingly on the front passenger side Ford did not install plastic retention stubs but Odero included some that basically just have carpet gripping spikes on the bottom. I've not installed them yet as it started raining and I am made of sugar.
Second Row
Second row coverage is really good. The mats come right up to the center console and also right up to the seat tracks. There's just really not a lot that isn't protected here.
Second Row Pass Through
Coverage on the second row pass through is pretty good as well. One thing to note is that the second row, second row passthrough and third row are all a single unit. I'm not entirely sure how I feel about this. The result is that these mats are clearly intended to stay in place and not be something you remove with great frequency. It's not hard to take them out, it's just if you're removing them because they need to be cleaned then the chances are good you're also going to get a little dirty in the process of removing them and trying to keep the dirt contained to this large mat. Nothing a quick sweep of the vacuum can't handle to get most of the loose stuff out before you remove them for a thorough cleaning.
One day someone will figure out a two or three piece design that limits the ability of dirt to get under the mats. Its a harder problem to solve for well than it sounds like as I've had two and three piece designs before and dirt always gets underneath them where they meet, even if they overlap.
