DanTheMan97
I've got a 2005 xlt that I use for both my daily driver & work. Roughly 80-90% of the time is towing a car hauler which has an empty weight of roughly 2000lbs & gets loaded with anywhere between 2000 and 5000lbs on any given day.........Now before you guys get your ******* in a bunch, I know these are not technically made for constant towing of this weight and blah blah blah...... I do plan on probably buying a Diesel F=250 eventually. Anyhow, one of the stock shocks appears to be leaking oil & ride isn't what it should be. What brand/etc do you guys suggest? I want something that'll put up with the abuse from both Michigan roads & heavy load. Thinking about buying entire strut assembly.
