1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Bilstein 5100 upgrade
Discussion in 'Suspension' started by Langer, May 4, 2021.
  1. Langer
    Langer Full Access Members
    34
    352
    159
    Mar 27, 2019
    Chicago
    Morning,
    This past weekend I got around to putting the 5100 Bilsteins up front on my 2017. I had the alignment done and I’m hearing a fair amount of squeaking even with small bumps while driving. Is this just a sign that I need to tighten up all the nuts that I had to remove to get the new shock/strut on each side? This is my first rodeo doing this so just not sure if that would be a symptom of those being loose, or if I should attack somewhere else. The upper control arms don’t contact the springs while driving, or turning, so I think that’s out.
    Thanks in advanced.
  2. mjp2
    mjp2 Full Access Members
    292
    166
    Apr 19, 2017
    Howell, NJ
    Did you torque things down with the wheels off the ground or on? Guideline is to assemble everything kinda loose, set the truck down on its wheels so the weight of the truck is on the suspension, and then torque things down as the parts are in the zero'ed out position.
    Langer likes this.
  3. Langer
    34
    352
    159
    Mar 27, 2019
    Chicago
    That’ll do it, hopefully.
    mjp2 likes this.
Share This Page
