I've been considering adding Bilstein 5100s to the front and rear of my 2022 Timberline for a mild 1.5" lift. I know the Timberlines are leveled from the factory, but I don't know how that is achieved. Are the springs mounted higher on the shock bodies? Is the spring taller? Is there a spacer I'm not seeing? I'm wondering if the Bilsteins will result in the same factory leveled height, or if the additional 1.5" of lift will be gained.
I suspect the rear height of the Timberline is the same as the other trims, although I haven't confirmed this. I'm guessing the rear will gain the expected 1.5" in height.
Does anyone have some insight that would help me better predict the results of this modification?
