Temperature Blend Door Actuators
The DATC system utilizes two temperature blend door actuators to control two separate temperature blend doors that independently vary the LH and RH side temperature settings, as desired. The temperature blend door actuators:
- are located on the plenum chamber.
- move the temperature blend doors on command from the DATC module.
- contain a reversible electric motor and a potentiometer. The potentiometer wiper is connected to the actuator output shaft and moves with the output shaft to indicate the position of the temperature blend door.
- receive a reference voltage to one end of the potentiometer. The voltage available at the wiper indicates the position of the potentiometer. The expressed value of the actuator wiper voltage is sent to the DATC module and is matched with an expected wiper voltage value. The DATC module then drives the actuator motor in whichever direction is necessary to make the actuator wiper voltage match the expected DATC module wiper voltage value.
Vacuum Control Motors
The three vacuum control motors have the following characteristics:
- They are actuated by the ATC solenoid and manifold based on input from the DATC module.
- They position the mode doors to direct system airflow to the vehicle interior as determined by the DATC module settings.
- The air inlet door vacuum control motor is a single-diaphragm actuator with a single vacuum source.
- The airflow mode door vacuum control motors are double-diaphragm actuators with two separate vacuum sources to allow the actuator to fully retract or partially retract.
- When vacuum is applied to both vacuum sources, the actuator will fully retract.
- When vacuum is applied only to the partial stage vacuum source, the actuator will partially retract.
Part numbers:
Defrost Actuator 8L8Z19E616C
Recirculation Actuator 7L1Z19E616E
Temperature Blend Actuator 7L1Z19E616C
