Rojo
So owning 4 out of 5 older vehicles and all 4 had something to fix. The other day heading out to the river the heater wouldn’t blow hot air, I could hear a clicking sound coming from near the blower area. After researching the problem I found out there are small plastic gears in the HVAC door motors that strip the teeth. This is the video I watched before attempting the repair. I will tell you this the Ford Mechanic (Very Good Mechanic, my Guru on Ford Repairs!) must have much smaller hands than mine. My hands are cut up from shoving them between all the metal and plastic.
//youtu.be/y2Bh4pN27zI
You start out by stripping the Instrument Cluster trim off. Numerous switches are mounted within so you must unplug everything before removing. I had to remove the stereo too.
After clearing out the big stuff I had to remove the glove box too. I could not fit where I needed to to get my hands shoved up in the hole made by it’s removal.
So the Blend Door Motor is way back under the dash. Under the radio the clearance was so tight I couldn’t get a single finger to fit far enough back to hold the Gear Wrench on the back screw. I used my Cat Claw (Red Handle Trim Tool) to hold the wrench down while moving the handle between the tips of two fingers on my right hand working thru the Glove Box opening. I will say it now, that back screw was Never going back in from the start. Well I stuck to the plan, if I ever take the dash off I will install it then, until then though I will have cold AC and Hot Heat.
Continued
Continued
