Thanks, but I ended up getting BLIS capable mirrors. That's all mine needed.I know this is an old thread but I am looking into adding BLIS and the codes needed to do that. In the IPC module configuration, look for line:
720-03-01
Look in the first set of 4 values. The first character is "4" to enable BLIS. My truck does not have it so this value is "2" in my code.
Hope that helps!
PS For anyone else looking into adding BLIS, I am just starting to collect information. In addition to the above, I also discovered the following:
720-01-01
Look in the last set of 4 values. The first character is "F" to enable Cross Traffic Alert in the IPC. My truck does not have it so this value is "2" in my code.
This info I found was for a different 2017 Ford vehicle but it has the same instrument cluster.
