Blue smoke from exhaust ?!
aziz
Kuwait
Hi my Expedition 2019 limited
When Start the car from cold start like 2 hours or more some time smoke for exhoust for 1 second . I send the car to dealer last week they change both turbo but. Today i start the car and i saw smoke for secend again What could be the problem ?!?
Update after second star i got engine light.
By the way yestrday i changed my gas from 91 to 95. Is that mabye the problem ?!?
BigOleFordFan
Zoom Zoom goes da "Tang" !
@aziz
Your title says "BLUE" smoke, which coming from the exhaust, usually indicates oil getting into the combustion chambers, via leaking seals, gaskets or piston rings....
However, WHITE smoke, if only seen for a moment after starting, is usually nothing to worry about as long as it goes away quickly. However, if it continues beyond a few moments, generally indicates some water, condensation, or coolant getting into the combustion chambers, in a similar manner as above....
Since you mentioned changing gas, perhaps the new stuff was contaminated with either water or oil or something else....maybe switch back to what you were using before & see if there is any difference....
Either way, you should NOT let it continue without having it looked at by a competent repair shop, as the needed repairs could be somewhat extensive AND expensive....
And where did you get "95" gas ? Usually 93 is the top grade available at most gas stations.....
HILLY
Greenville, SC
@aziz
The guy is from Kuwait.
ROW usually uses RON rating system vs. NA using AKI.
Ratings are usually:
95 RON = ~91
98 RON = ~93
100 RON = ~95
This is also why imported cars tend to specify using higher octane ratings (i.e. 91) here in NA as our top tier here is their low/mid tier there.
HILLY
Greenville, SC
When Start the car from cold start like 2 hours or more some time smoke for exhaust for 1 second . I send the car to dealer last week they change both turbo but. Today i start the car and i saw smoke for second again What could be the problem ?!?
By the way yesterday i changed my gas from 91 to 95. Is that maybe the problem ?!?
Smoke color plays a pretty big indicator.
As mentioned, white smoke is coolant getting into the combustion which would generally be a head gasket leak.
Thin white smoke quickly dissipating would just be condensation in the exhaust system that would blow out/burn off quick, but I don't think that should be a problem in Kuwait.
Blue/grey is oil burning in the combustion. Causes are piston rings, valve seals, or faulty turbos (blow by).
Black is rich fuel mixture.
Switching fuel grades should not have had any bearing on this. In fact given location and octane ratings, I would probably rule out bad gas. Need to get a scanner and pull the DTC's triggering that light.
aziz
aziz
Kuwait
@aziz
They told me mabye there is still oil in the exhaust .. and need some time to be disappear. But the engine light is the big problem now and im waiting for the report today
aziz
aziz
Kuwait
Hi guys i got call from the dealer they told me (( oxagne (O2) sensor )) will be replace that why you got engine light in the dashboard
BigOleFordFan
Yea, but that won't fix the ROOT problem, but it should let the CE light go off for a while, until the leaking/excess oil contaminates the new sensor....then you will be "back to square 1" as they say...
And not getting the problem fixed for real will eventually cause your catalytic convertor to go poo poo also, and that my friend, is a VERY expensive repair ($1500-2500 !) :(
So in other words, be like the cable guy and "get 'er done" :D
aziz
aziz
Kuwait
Thanks man . So what do you think the problem is it catalytic convertor or gasket head .. im still seeing smoke from exhaust
bb37
Super Moderator
Member Relations Specialist
Indiana
That just looks like condensation in the exhaust system being boiled off by the hot exhaust gases.
BigOleFordFan
^^THIS^^
Based on your video, that quick puff of smoke is not that unusual, but would warrant keeping an eye one for a while. If it becomes more frequent or increases in intensity/lasts more than a few seconds, then get to a repair shop quickly.
But for the moment, the important thing would be to have it scanned to get the code(s) for whatever is causing the CE light to come on, and then fix that issue first.
Note that in recent years, I have seen that with some cars, the CE light coming on is more because of a bad sensor somewhere, rather than anything serious actually being wrong or some component failing or getting ready to fail.
Good luck if you actually need any repairs, and please update us with whatever resolves the issue.. :)
Mr Big
Tampa Bay, Florida USA
This is the smoke .
They changed both turbo
They change O2 sensor
https://streamable.com/cvvl2x
If the inside of the exhaust pipe is dark or black, then it could be oil or running too rich. If it's tan color you're good to go.
That looks like condensation, which is common. I have it here in Florida, in the morning.
Your O2 sensor error code has a recall, here in the states, that is also tied to pcm and temperature.
aziz
aziz
Kuwait
The car with dealer they said we gonna check the engine it will take 10 days and more .
