duneslider
I will start by saying I don't know exactly what the BMS is doing in the Ford but I don't think it is doing what a lot of people think it is doing. Based on what I have been able to dig up all it is doing is watching the voltage to make sure things (accessories like lights, chargers, radio, etc.) aren't draining the battery below the point the vehicle won't start. It is not managing how it is being charged, or some magic device that prevents self-discharge. I see online where people state the BMS is set to only charge the battery to 80%, I do not believe this is true, even if Forscan is showing some sort of setting like that. The 80% rule only applies to lithium family batteries like those used in hybrids or all electric vehicles, it would not be used on an AGM battery. I think when people see the 80% setting in forscan it must be a setting that is in the code for hybrids/electric vehicles.
AGM's need to be fully charged at all times to get the greatest life out of them. If you do a lot of short trips, and have auto S/S active the battery probably is not getting fully charged and will lot last as long. It would be good for people to put their batteries on a true battery charger on a regular basis to make sure their batteries are properly maintained and fully charged as much as possible.
If anyone has any official Ford documentation on the BMS I would be interested. Reseting the BMS (like mentioned) really isn't needed and should take care of itself in a short amount of time but I could see that maybe your remote start or auto S/S wouldn't immediately return after replacing a bad battery but likely by the next day it would all be active again.
