Brake release noise?
jr1under
Aiken, SC
When shifting into gear, my 1999 makes a loud grinding type of noise. It's hard to describe sounds with words so I put a short video on YT if you want to hear it. Seemed to me it was coming from the rear U-joint, not something I'd work on myself, so I took it to a shop. They said it wasn't a UJ, it was "brake release noise" and is common in vehicles of this advanced age. No problem found, no charge. But it's still really annoying and I'd appreciate advice on what's causing the noise and how to quieten it down.
AWAR
oregon
Take it to a shop that can actually repair drum brakes.
Billme
Hattiesburg,Ms
I think you better look at that pinion bearing more closely.. It looks to have horizontal play.. If so, there is your grinding noise..
jr1under
jr1under
Aiken, SC
After researching this...damn, for three years I've been hearing hoofbeats and assuming zebras. The shop(a dealership btw) told me it was brake release noise and nothing to worry about. So I didn't only now to discover it's a drivetrain component that's failing and should be dealt with promptly. No other noises when driving but the rear diff is leaking - is that related?
No way I'm going to fix this myself, I just need to understand what's going on before taking it to a shop.
Billme
Hattiesburg,Ms
You certainly want someone to verify it.. The leak could be related, but I don’t see any from the pinion…You just want to verify the horizontal movement of the pinion, If it is, fix it..Mine is wore out too..I know it will have to be dealt with soon..
My Forscan came in today, and you’re right, this lite version is much more powerful than what we have..Amazon sent the wrong Evap connector so I got to deal with that tomorrow..
Let us know what your mechanic says
Good luck
jr1under
jr1under
Aiken, SC
In the video, using one of the fins on the differential as a reference point, I can see ~1/4" horizontal motion when the truck goes in gear. Is that what you're talking about?
Billme
Hattiesburg,Ms
Yes, any side to side movement means the pinion bearing or most likely the pinion gear is worn out.. if there is no excessive vibrations and maybe driving local, you can get by for a while, otherwise Get her fixed..
Billme
Hattiesburg,Ms
Making sure you understand what I’m saying.. I’m talking about Side to side, or even up and down movements, not radial movement of the shaft and pinion as it turns showing slack
jr1under
jr1under
Aiken, SC
Thanks, should have rotated the video 90* before posting it. My understanding of what you said...the picture shows the diff moved from the green line to the red when shifted into reverse.
AWAR
oregon
The movement you are looking for is between the round flange and the housing, not that the housing moves when shifted out of park. Secure the car so it cannot roll. The parking brake and chock the tires will hold on flat ground. Place the transmission in neutral, let your foot off the brake pedal. Make sure the car cannot roll. Crawl under and twist the driveshaft in both directions and observe the movement of the flange where the driveshaft attaches to the differential. Some rotational movement is allowed due to all the gears inside the differential. Take pictures of this movement to show us. Now lift the driveshaft and observe any movement up and down, there should not be any movement up and down. Now try pulling and pushing the driveshaft forward and back, there should not be any movement forward and back. If there is up and down or in and out movement the differential needs bearing to be opened and inspected.
Hope this helps.
jr1under
jr1under
Aiken, SC
Turns out there were two separate problems here, the brake release noise and a differential leak.
The diff gasket was bad(even though only 3 years old) and had leaked enough fluid to be scary low. Fortunately, no metal shavings in the remaining oil or on the magnet. I used a Fel-Pro gasket again...do you guys use store-bought gaskets or Gasket Maker?
The noise is still there so I plan to do the tests @AWAR suggested as soon as I can fit the truck into my garage. We're rebuilding a deck right now and the garage is crammed with deck boards, sawhorses, paint and the such.
Al_Harley
