@BaggedExpy That attatement didn't come through. Can you fix it? I'd actually like to see what sort of mod you did there. It sounds like you modified the seat to fit the floor, not the floor to fit the seat. That would be much more doable IMO.I have the same floor plan. Only hooks on pass side. So i took driver seat apart removing hooks and made seat feet out of angle iron. Had to drill 2 holes for right side front and rear feet.
@BaggedExpy So you went from bench (your floor was set up for bench?) to buckets, and you modified the buckets to bolt down instead of latch in. Is that right?
I have the opposite problem, and nothing to bolt to (only latches on the floor). Might be quite the engineering mod on a bench seat to get it to latch in where the bucket does.
