Camping trailer towing question
Logan97
AZ
Good afternoon everyone, I'm looking into purchasing a camping trailer and need to know if the one I was shown at the lot is too big for my expedition. I have a 13 el xlt with the heavy tow package. The trailer I'm looking at is 37 feet long, 11 feet tall, and weighs almost 7700 pounds. I've pulled something that big with an f150 before but need to know if the expedition can do it. It will be towed up a mountain to get to the campsite and It'll be about 3 hours of driving one way. There was another trailer that wasn't as long but I like this one because the trailer I get needs to hold 6. The link will also be on here of you need more info on what I'm looking at.
Fasttimes
Miami
I wouldn't. That is too long and too heavy imo. Assuming you're going to pull that trailer and have 6 in your Expy? What is the tongue weight of the trailer? That 7700lbs will be 8500 after you put stuff it in. You will have certainly exceeded payload for sure of the Expy when all is said and done.
I tow a 30' RV, about 6600lbs, 2 adults, in a 2017 Expy with Heavy Duty and I feel I'm at the limit for an Expy with my set up. And this is after dialing in the WDH hitch, upgrading tires, and doing everything I can to beef up the setup.
shane_th_ee
Seattle
That’s too long and too heavy for your Expedition. That said, there are lots trailers that fit 6 and which are also a good match for your Expedition. (We fit 6 in a trailer with an 18’ box.)
JasonH
Houston, TX
I strongly suggest reading some of the other threads on here about trailer specs and towing capabilities. That you inquired about a trailer that size suggest you're not fully cognizant of the Expedition's towing limits. Start with the towing guide from Ford and read some other threads so you have more knowledge about how to calculate safe tow limits. It's your family's life on the line, so you don't want to taking unnecessary risks.
Dealerships are reknown for sending people off the lot with oversized campers and poorly configured hitches. Once you pick a trailer, perhaps consider renting one with similar dimensions to see how you feel pulling it with an Expedition.
CharlesA
south dakota
We pull a 33ft with our 5.4. Just got an ecoboost to try next weekend. I don’t know if I would want to go the extra 4ft however. I’m sure you could do it but it may not be pleasant.
Left Coast Geek
Mid Left Coast
per https://www.crossroadsrv.com/products/travel-trailers/sunset-trail/floorplans/ss331bh/ 7800 lbs is the *DRY* Weight. you don't ever tow a camper empty and dry, except maybe home from the dealer. that camper has a 1900 lb payload, and believe me, no matter how hard you try, you will be MUCH closer to the GWR of 7800+1900 == 9700 lbs than the dry weight. allow 400 lbs for water + propane, and you're down to 1500 lbs of food + beverages + bedding + clothes + gear on the trailer, you'll hit that a lot faster than you might think.
I would recommend an F250 crewcab for that trailer with 6 passengers.
Silver-Bullet-Bus
South Carolina
You are definitely going to be overweight with that! I’m at about 6,600 dry & 7,700 loaded & I would not go any heavier than that. Additionally, I would take off another 500-1,000 pounds if you ate bone stock & not modded. These things will overheat when you treat them like a billy-goat.
Especially, the trannys because from the factory, the tranny can not get any colder than the the ECT, because Ford cools the tranny heat-exchanger with hot engine coolant.
I don’t care what Ford or Chevy or whoever says—they all lie, or the max number is really only sustainably maintained over flat land.
Hope that helps.
