notamechanicbrad
I just purchased this 4wd 2011 Expy direct from the owner (not a used car dealer). They claimed they knew of no issues with it but were just driving it short distances a few times a month. But, I plan on pulling a 16ft box trailer @ about 5000lbs all day everyday.
So...I took it on a test drive with an empty trailer for about 80 miles. The truck runs and shifts fine. But I believe the transmission is not cooling properly. I drove it 40 miles then got off the highway and was sitting in a parking lot for about 15 minutes with the truck running. When I put it in gear it almost feels like the emergency brake is on. Once I get on the road it seems to drive fine. Im thinking the transmission is getting hot. Or could it possibly be a problem with the 4wd?
I am going to do a fluid and filter change and upgrade the cooler with a much larger one. I would like to be able to monitor the trans temp. Im trying to figure out if this truck already has a trans temp sensor. It has no trans temp gauge.
Any suggestions??? Before I spend the time and money on my planned transmission "maintenance"!
