Catch-can question
C
creef14
VA
Its tight but fits with no clearance issue. Jlt included a can koozie and decal at no charge!
Sent from my Garage using Tapatalk
Looks good. I just ordered one too.
Capacity is really only an issue for me in the winter, so with this setup I may be able to make it through the whole summer.
mquick5
Buckeye Country
I wonder why they dont add a drain valve on these? Seams it would be just as easy to R&D that, as it did the can extension! Perhaps I will reach out to them and recommend that to them. It wouldn't take much if you had a tap. Certainly would cost less than the $39, for a petcock style drain valve.
3tonsoffun
Probably bc of location, would be difficult to get something back in that corner to catch what the plug drains out without having to run some hose way down low to access under the truck, then that hose gets gunked up. Now the higher $ ones that mount to the front of the radiator a little different story. I think for our 3rd gens the 3oz is perfect if emptied 2x between oil changes. At least it is for me. You just need to be very mindful of when the last drain occurred as Ive seen several f150s messed up due to overflowing cans. Also, don’t forget to clean the filter in the top part of the can lid every 10k miles
John D
Memphis
You got a link to messed up f150 threads? I have unscrewed mine to find it full a few times and worried about what would happen if not emptied in time.
3tonsoffun
I’ll see if I can screen shot the posts from the FB page. Basically it causes a lot of misfires and engine runs really rough
John D
Memphis
Got it, I also had not read you should clean the filter on the can before so thanks for that!
mquick5
Buckeye Country
It's in all the instruction manuals. I think for the 15-17 expys it says every 15k. I'm just not sure if you have to remove the whole setup, or if you can unthread the 2 hoses?
Sent from my Back Porch using Tapatalk
3tonsoffun
