CCD Aftermarket Parts
grey1169
Wisconsin
I have a 2015 Limited EL. When I go around corners that have a lot of bumps the rear end tends to bounce out from underneath. I suspect I need new struts.
I have the CCD struts. It seems like the only parts (non OEM) that I can find have the CCD delete option. All of these options come with the full strut and mounting plate so it is easier to replace the whole unit.
Arnott SK-3598 is one of the one replacements.
I have a few questions.
How important is the CCD components? Are they auto leveling or just an adjustable shock?
max78
AZ
CCD = Continuously Controlled Damping, it just adjusts the dampening based on conditions, does not auto level that I know of. . . you might get a light of some kind unless you disable them not sure. We have normal struts on ours and they are fine.
17expi
Mt Shasta Ca
I would delete them
gunner1416
