Check 4x4 in 4L Only
Kjhawkeye1
River Falls, WI
Like the subject says I am getting the "Check 4x4" with a wrench sign when I try to shift into 4L only. I thought it was the 4WD transfer control motor (2011 w/ 155K miles) so I replaced it, which is a super easy job.
Bolted everything back up, cleared the computer, restarted it and everything shifts just fine but still a no go for 4L.
I do not anticipate needing it hardly at all (do go into corn fields after rains to pull out empty wagons at harvest) but I like my vehicle to function as it should. When I have tried shifting to 4L I am always in park.
Appreciate helpful thoughts on this.
Kjhawkeye1
Kjhawkeye1
River Falls, WI
Update on this... What was posted worked but I had to cycle thru a couple of times, and drive a few feet, put the vehicle in neutral with foot on the brake, and then went to 4L. Thanks for the help.
Goofy173
Ky
FYI, didn't it say put in neutral on the dash display, when you selected 4L?
It knew what it wanted. You just wouldn't give it. Lol
You're right. That is an easy replacement though, that motor. It is probably the easiest job of any on that truck, that is a major function.
Kjhawkeye1
Kjhawkeye1
River Falls, WI
It did not for some reason and would have been helpful. Even turned the dial slowly because I thought I had been turning it too fast.
savbraze
