Tossing this out as I’m stranded 3 hours from home trying not to throw unnecessary parts at it.
05 Expedition, EB Edition, 5.4 3v. dash message “check electronic throttle control”.
I replaced the actuator and the TPS, disconnected battery while working on it to reset PCM. Used FORScan to reset DTCs. Key on engine off, same codes come back, stuck in limp mode- PCM codes 221, 223, 2104, 2106, 2111, 2135.
I did not replace actual throttle body as #1, it’s hard to find in stock, but I do have one available if that’s the cause. #2, it seems to be working as expected mechanically EXCEPT in wide open throttle, the butterfly shudders/shakes slightly but rapidly. I don’t think that’s normal but I’m not a mechanic by any means.
I’ve physically checked for obvious wire shorts in places that I’ve seen mentioned, as well as everywhere else I could reach /see.
1st Screenshot is current KOEO relevant data, pedal full release. TPMODE says WOT at all times, all pedal positions until you release the pedal, then shows CT for a second maybe, then returns to WOT.
2nd screenshot is same key position, full throttle pedal.
I can’t keep throwing parts at it, and I can get either the throttle body, or the pedal position sensor with the $ I have. Anyone have any quick input that will get me back to running?
