Irish Medic 51
Already checked all that no problems
I reinserted it and viola. I Hope yours is that simple.
Good luck.
Were you ever able to figure this out? It sounds like I have the same problem.
Everything works except when I turn the key, the starter relay clicks but it doesn't start. I can jump it at the solenoid and it starts right up and runs fine.
Were you able to fix this issue?? I have the same problem. I have no ground signal from the ECU to the starter relay. If I jump the starter relay the engine cranks for it wont start even with ignition on the run position. Any ideas on what else to check ??Can the fuseable link be bad and still allow the fuse box and ingtion to have power but not allow it to start
That member has not been here online here for almost 2 years.Were you able to fix this issue?? I have the same problem.
