Climate control panel
Ricks Expedition
CA
Help, My climate control panel stopped working. I checked all the fuses in the engine fuse box and the fuse box on the passenger side. All fuses are good. I also removed a good relay and plugged it into all relay positions. No power to anything on that panel. 2014 EL Limited Expedition with 125,000 miles.
drscanman
West Lafayette, IN
Dang, fuses good, ok, I am assuming everything else electrical on your EL is working fine? Ground wires come to mind first, their connection is good, clean and tight. If the HVAC panel still has no power, check the main under-hood fuse box for blown 40A-60A fuses related to "HVAC" or "Blower". I would pull each out and check to make sure they are good and also no corrosion in the fuse pin receptacle or on the fuse prongs themselfs.
