Yes, they replace your oil and coolant.
And they should replace EVERY gasket, every seal, and every o-ring they touch as they remove interference parts. My Ford engine guy took the time to go through the list with me, while pointing them out on the car.
He also replaced BOLTS. Specifically, intake and timing assembly bolts that get torque spec that includes “stretch”. He said the bolts were one-time use only, and should get replaced anytime they have to be de-tensioned.
Make sure you bring that up.
I also had them replace the water pump while they were in there. This isn’t included as part of the TSB, but I think you’d be crazy not to. Water pumps don’t last forever. The part is cheap. But the labor to replace it is beyond stupid.
But while they have the front cover off and timing hardware removed to address your cam phaser problem, the labor to replace that water pump is exactly zero.
Since mine already had 50,000 miles on it, it was definitely a no-brainer.
I am under the impression that the water pump is external on the 3.5 EB. Gen 1 EB had external water pump.
Are you sure it is behind the timing cover??
